I had to replace the passenger speaker (blown) and door handle today so i thought i'd post up a how to. There is a link for removing the rear speakers, you just pop the panels off, but you have to pay to see the front removal. This is an easy easy job to do and shouldn't take more than 30 minutes, i'm posting this because it's just kind of nice to know what you need to take off so you don't break anything and have to make a trip to the junkyard. You can get a trim and molding tool set for cheap from harbour freight, here's the link ( http://www.harborfreight.com/5-piece-auto-trim-and-molding-tool-set-67021.html )hard to beat for $8.
Here's the broken door handle(new ones are only $9 on ebay), just waiting for someone to snap it off...
First unscrew the lock (wow!), lefty loosey...
Next, pop off the door handle trim...
Then, on the door arm rest, pop out this piece with a flathead screwdriver and remove the screw that was beneath it...
Remove the arm rest, it slides out then pull up...
After that you'll see two screws (or 3 if you're a 2 door), remove these...
Then pop off your window switch...
That's right, you guessed it, unplug the window switch...
Now you can begin removing the tabs that hold the door panel on with your panel tool from harbour freight, there are 11 of them...
