sailone32003
Everything posted by sailone32003
  1. Hi Everyone, I think I saw this discussed before but can't find it. My engine is making a clattering sound. I be leave from the lifters has anyone found a remedy for this? Thanks All Sent from my iPhone using Tapatalk
  2. I would make sure that the oil is not coming from the valve covers before bothering with the rear seal. The covers are known to leak. I replaced mine and no more oil leaks. Sent from my iPhone using Tapatalk
  3. Ok I think I have a new one for every one. My starter was starting intermittently and I replaced it. After replacing it it started fine a few times then when I turned the key off the starter was still spinning, so I disconnected the battery to see if something was hung up, reconnected it but still spins and if I turn the key the solenoid does not engage. Any ideas?
  4. Ok just put in a alty for a 88 maxi in my 93 pathy pulley doesnot line up and rubs on ac belt what gives?????
  5. ahardb0dy If you dont mind where did you get the terminals?
  6. Nothing there but a plastic box some connectors for the lights and the fuel filler.
  7. Hi William, Will do as soon as I figure all the wiring out.
  8. The amp I found behind the head unit is some what round and I pulled the connecter out and it has a different pin configuration then what was pictured. And any Idea where the other amp is looked in back and did not see them. Thanks
  9. Thanks But does not apply to 1993.
  10. Thank you for the link can you tell me if this leaves the factory tweeters working? thanks
  11. Can someone tell me the location of second amp removed the one behind head unit. Also any input on jumping the wires on the amp connector would be greatly appreciated. Thanks again.
  12. Sorry if this has been asked, but could someone tell me how to remove inside trim on 93 windsield post, trying to replace tweeters thanks. And Happy new Year to all!
  13. Sorry if this is already answered. Has anyone run across this? When towing I get a vibration that rolls in and out starting at 60 mph. Thanks Paul
