Daves94XE
Everything posted by Daves94XE
  1. Thanks I'll check that out. That's what I plan on doing to save some cash use my Lego's I have now.I know thats kinda a odd tire size tho
  2. Daves94XE
    tires
    Anybody running 33x10.50/15s or 33x11.50 15's on Lego's? O
  3. 267,000 miles on my 94. Im the second owner. Had timing belt changed at 135,000. Guess its time for one lol
  4. 267,000 miles on my 94. Im the second owner. Had timing belt changed at 135,000. Guess its time for one lol
  5. Yeah but how bolt on is an r50 tho
  6. I adjusted the throttle cable and no more probs.did find the cable nuts loose tho
  7. Ok heres my problem. I have a low idle around 500 when I turn the ac on. Is there an idle sensor to idle the engine up when the ac is on? Its A 94 xe.
  8. it was bought at North Olmsted Nissan in Ohio. and was brought here after only a yr. that maybe explain some of it. it could have been a area type alteration. i looked and it is a Funstyle Blendix Countess sunroof.i found the kits but idk about the parts they offered a hardware kit for like 38 bux but no info of what was in it. tho mine is the only one like it i have seen here they are all factory or nothing
  9. this is the first one i have seen like this. all the ones i come across are the one with the shade cover screws in them and shaped different
  10. if anyone can figure out where i can find the hindges it would be a great help. or atleast one with that has the same hindges anywhere let me now
  11. i have been looking for a new hinge for my sunroof glass and all the factory ones i have found are made different. it has made in brazil on the glass. is this a factory sunroof or aftermarket? the plastic ears have broken off and if the others break im screwed lol thanks guys. http://s976.photobucket.com/albums/ae245/95xcabsilverado/pathfinder/
  12. i rewired it tonite using 4 way cable, in a shield cover.at first when i got it with the tailer hooked up it would keep blowing the pass brake light. thats when i rewired it, didnt have any probs till last nite. thinking bout pulling the pos u haul wiring box out.
  13. I work for a truck and trailer parts store, i may try and use breakers and might get new leds cause we can get them pretty cheap. Www.gpartsinc.com might help u guys on stuff we can use
  14. hey guys i keep having the same problem. anybody that pulls a trailer, what did you end up doing to keep from blowing light fuses. i know i have a good ground and i rewired the trailer through the correct plug. i have a 20 amp fuse and it still blows it. what to do... what to do...
  15. thanks man i appreciate it, i gotta weld up the bottom brace and straighten it out but now atleast i have an idea of how i need to redo my brackets
  16. how did you guys fab brackets for the arb and a 2 or 3" body lift?
  17. did you have to modify your arb when u did the body lift for the mounts?
  18. i dont think you will be dissapointed. i love mine. after i got mine, i turned my torsion bars up so it was alittle out of align thats y mine roars. but if its inline and they wear right they should be pretty quiet
  19. yeah sorry it took so long to get back to ya. ive had them for a year and have no complaints, havent really tried them in mud, but snow aired down to about 25 lbs they are awesome.they do whine alittle as do any aggressive tire. they have about 18,000 miles and havent wore maybe 2/32nds tread., when i bout mine they were 132 each not i think there like 158 each.buy the extra roadhazard its worthit
  20. it was on craigslist. i think what happened was the guy may have bought the bumper/winch and kept the winch but sold the bumper
  21. yeah I got lucky about a week before I found one with a 8000 lbs warn for 450. but didnt have the money. but I found this one right after he posted it last sunday. he was asking 200 but I offered him 100 and he took it.I figured he didnt know what he had lol
  22. http://s976.photobucket.com/albums/ae245/95xcabsilverado/
  23. i just scored an ARB today for 100 bux! granted it needs alittle welding in one spot and some hammering out. but hey for 100 bux who cares!
  24. i know there are very few of us ga guys on here, check out gatrailriders.com there almost all from our area.
  25. it wouldn't hurt to take it to a rep body shop and get an honest estimate.insurance companies are notorious for tryin to low ball the cost and they are bad about pricing it with used parts.since it was the other guys fault, they will try and get out as cheap as they can.
