JamesRich
JamesRich last won the day on September 4 2016
JamesRich had the most liked content!
About JamesRich
  • Birthday 10/21/1969
    87 Pathfinder SE 4X4
    Scott, La
JamesRich's Achievements
NPORA Old-Timer (5/5)
88
  1. The fun already began if you got it out already! James
  2. I'm thinking electric! I'm spending $80 to $90 a week on fuel! That would pay a note on a small electric car, leaf maybe! James
  3. Thanks for the welcome! I love it up here, not sure my pathfinder likes it up here though! I took it to work once and it don't like the mountains! Burned a half tank for the two hour round trip! got it floored going up most of the hills too! It sat for a few months in louisiana before I had a chance to bring it up so I'll give it a good tune up this weekend and try again next week. My Ram 3500 dully makes a whole week back and forth to work on one tank! Can't beat a cummins for power and fuel mileage!
  4. I'll have to do some searching, so far I don't know where much is up here! I live in Grandview and work in Lenoir city. slowly learning in between! I definitely plan to do some fishing up here! James
  5. Brought my pathfinder from louisiana up to my new home in Tennessee! Now to find some places to wheel! James
  6. Put some marvel mystery oil in there if you want to clean it out, works really good and it's been around forever and I've never heard of anyone having trouble with it. It will even clean out the ring lands and stop oil burning from stuck rings. James
  7. I've got a snap on 1000 series 4 box set full of things I rarely use. But when I need it it's there! That is at least when people that borrow them bring them back! The only problem with having a lot of tools, friends think I run a loaner company!
  8. y'all just need a better puller! I got a snap on cupped style puller years ago and never had a problem pulling a pitman arm again. Even on big ford 3/4 and 1 tons. Like this one. https://www.ebay.com/itm/SNAP-ON-TOOLS-CJ119A-Pitman-Arm-Puller-Most-Compact-Cars-And-Trucks/162843263771?hash=item25ea37031b:g:LQcAAOSwlxRaVQPA
  9. My thoughts exactly! If you did dish the flex plate, it may not be enough in front of the sensor to pick up correctly. If you can't see in the sensor hole directly use your endoscope to look in there and see how it lines up. I would pull the transmission to change that instead of pulling the motor again. James
  10. That looks great! I have been offline because my old computer crashed!! Built a new one and good to go!
  11. I used purple power to clean my heads when I had them off. I think i mixed it like 1 to 1 with water so it was really strong. James
  12. I thought about the intake leaking but the coolant passes on each end, and the middle cylinder on the passenger side is the only one that got coolant in it. I have the modified TBI intake with a carburetor on it. I've been starting it morning and night and it runs fine. After I get my dye tester I'll start driving it again. James
  13. I've checked it out really good and can't find any indication of a head gasket leaking! For that much coolant to get in a cylinder, it would have to be a pretty good leak. I let it sit 2 days with the plug out and no coolant collected in the cylinder. It runs perfect and no bubbles in radiator or blowing coolant out. Every time I check the radiator it is full, not loosing any coolant. Not sure how all that coolant got in that cylinder but i'm starting to think foul play! I'll have to start parking it where my security cameras can see it. I'll try running my dye tester on it and if it doesn't show anything I'll start driving it again and see what happens. I'll always be nervous when I first bump the key now! James
  14. JamesRich
    VG34ER
    That's awesome! I've got all the parts to build one just hadn't cut the pistons yet. Has anyone come out with a VG34 head gasket yet? Or the VG33 gasket still working? James
