brix542
About brix542
- Birthday 07/01/1994
1994 Pathfinder- auto, 31's
16-21
1994
Gender
Outer Banks, NC
brix542's Achievements
NPORA Veteran (3/5)
Need new tires 31x10.50x15 recommendations
brix542 replied to Stifun's topic in 90-95 WD21 Pathfinders
They look like the 15x8s I got on my pathy. -
Maxxis bighorns are a perdy good tire. I've got 31x10.50 on my pathy and they handle good and aren't too loud. Clears mud out good and handles good in rain and snow. Got right at 25-30k on them and still got round 30% tread. -
Pre Cut window tint... Has anyone tried it?
brix542 replied to JohnMasters's topic in 90-95 WD21 Pathfinders
5% tint is perdy dark. I did a 7" windshield strip on my pathy today and driving home tonight i could barley see through it when lights hit it. Glad i didnt go with the 2.5%. Thinks ima do the back doors and cargo area windows tomarrow in 5% if i have enough tint. Tried to do the drivers door in 35% but gasket messed me up and i ended up tearing the tint so i tossed it. Gotta get some more and try it with the door panel off. Only thing im not sure about is my sun roof. It looks like it would be real tough to do the inside cause of the pieces for the cover to screw onto. Is there a special type of tint for exterior use or would i be fine with the same stuff im doing on the inside? -
Not quite sure what your saying but i think you mean shaking/wobbling? If thats what it is id first make sure your wheels are balanced good. Cheap and good chance of being the problem.
Im really liking em. They are lighter then my old rims and the stance on her now is perdy agressive looking. Plus they just look good on mine. I still gotta crank the t-bars a lil to stop the scrubbing. Hopefully will happen this week. Got full access to a 4 bay garage mon.-thurs. for 2 hours each night. Only gotta supply parts. Best part is im getting college credit for working on cars. Hardly any book work in the 2 classes.
Once the new handles come in il give everything inside a look at and spray the moving parts. From looking as i close the door the striker seems to be allinged with the latch. Could being to far in or out cause this?
uncc, thats what ive started doing since i last replaced it. Forgot to do this yesterday when responding to a fire call. I dont mind doing this but something doesnt seem right with the door. Handle easy to pull till the very end then real hard and opens with a pop.
Is it locked or just stuck where it wont open? When i replaced the hinge pins my dad closed the door before i could hook up the piece that stops it from opening too much and the door got stuck closed. Had to push the door in and then pull the handle and open it.
I actually replaced the hinge pins on the door a week ago. Had a good 1-3 inch of play and now if you lift on the door you lift the body as well. The metal hoop that the door latches onto was gouged bad so i replaced it with the one of my parts truck. It has slight scraping on it but was alot better then the other. Im thinking that maybe this isnt in the right place?
Thanks trog. Hopefully this pair will last. Replaced the drivers side 2 times since the last december and it halfway broke again tonight. Guess i really need to figure out why the door is hard to open.
On my driver side door, ive had problems with the exterior handle breaking off. Part of the cause is pressure on my door from somewhere(which im trying to figure out) that causes you to have to pull harder on the handle. But the other cause is that the replacement handles are made out of plastic and look cheaply made. Is there anywhere i can get a all metal handle?
starter swap without removing the oil filter?
brix542 replied to Balln's topic in 90-95 WD21 Pathfinders
I did mine the same way nismo. Just didnt pull anything but the starter bolts. Wiggled it out the front and was good to go. Only took 10ish mins of tugging and "persuasive words" and i had it out. -
I imagine with the bodylift it would make it alot easier then it was for me. Just take your front skid off and then unbolt the starter and slide it striaght foreward. WIth a lil wiggling it should slip right out. The wires should be long anough to extend out the front which makes it easy to disconnect them. -
Nice186- 31x10.50s on stock rims orta fit fine. The bighorns i have now are my second set of mts on a stock pathy. First was some nexens. Both didnt scrub. Only reason they scrub now is cause my new wheels offset is different. But if your front has sagged bad you might need to crank your t-bars. Which are torsion bars. http://www.nissanpathfinders.net/forum/topic/27538-front-torsion-bars-and-adjustment/page__p__513421__hl__+how-to%20+crank%20+tbars?do=findComment&comment=513421. That thread shows you how to adjust them. You can also reindex them if you dont have enough. Theres a thread on how to do that in the garage section hardbody- Im not quite sure. I got 3.25-3.5" when i measured em.
When i replaced my starter bout a month ago all i did was drop the front skid and wiggle it straight out the front and this was on a 1994 SE with an auto trans. May take a lil longer depending on how difficult it feels like being that day but fairly easy to do. Just gotta watch were your hands go. Some stuff under the truck seems to like to gouge them.
