BigD21
About BigD21
  • Birthday 04/01/1968
    White 1988 WNYD21 2dr Wagon, Z2.4S twin spark engine, 5Spd Man, OME Gas Suspension on 2" Lift, 265/75/16 Cooper AT's on Trak Sunrasia Whites, Custom Idler Brace made from two bits of right angle, Aluminium Bull Bar with 360W GE Forward Lighting, Truck Battery, Kenwood Audio with Tape Cassette CD adapter, Manual, Air, Steer, Snatch Strap, Tool Kit with enough bits to get me out jams, was a past member of the WD21 damaged reality board until some tool destroyed it! I miss that knowledge goldmine and its amazing content.
    Skilled/Experienced Mechanic
    ST
Contact Methods
  • ICQ
    bigd21
    NSW, Australia
  • Interests
    all things good
BigD21's Achievements
  1. Aye curumba .. thats what I feared the pro shops have a booty stretcher but in order for it to work you must be able to clear the CV at both ends .. yup it looks like the diff side is just bolts/nuts but the outer is a very large and super tight nut inside the locking hubs.. Maybe this could be a job for .. .. .. "Batmechanic" and his sidekick "Robthem" on the labour well some things you just cant do yo self
  2. Excellent info .. 5.25" (13.33mm) OD is around about what I get measuring from the base of the spring's using my cheap but almost precise chinese caliper. The guy on ebay I found sells a 15mm (5.90" to you guys)lift polyurethane set for the Nissan GU/GQ patrol But sadly he doesnt say anything about the IS & OS diameters I hope his gear works with my stock pathfinder springs IS - OS diameters it would get me out of trouble .. I'll Q him. I cant see if theres upper rubber isolaters but your advice and logic tells me that there is so if the ebay guy cant help me then I'm going to print the link info and head down to the Wreckers to do me some pulling proly think a firmer set sounds rational after all those hard corrugated trails we have here could do with some tempering. Cheers and beers
  3. Sorry for a mundane Q but can you tell me what the rear spring seat size and widths for the WNYD21 is as my lower rubber ones have perished and Ive found a guy selling 1.5in urethane lifty types on ebay for dog cheap. I did the fourum search and the v8 JGC is all that I can interpret to be the best fit?, in the good ole days I do remember someone saying the jeep cherokee front springs were interchangable with the WD21 rears, does anyone know from which model year exactly? or do I need to pull them and take them with me to the pull your own parts yard? for the full comparison Mine are a little saggy probably due to the rubber being totally shagged from my many off road adventures as well as their age, so Im thinking new(ish) springs and spring seats. just need to know thier dimensions before I go out to buy. Cheers and beers
  4. Hi, I'm an 88 Pathfinder owner in need of some advice in regards to replacing torn CV boots, Has anyone done this proceedure, if you have can you please give me some advice on how to pull it off .. wo 2 go! I have the oem boots and the grease and the "well equipped" home workshop .. .. just no clue on the process Thanks in advance BTW: Some bogan pathfinder owner in west sydney stole the original FSM from Penrith public libruary and if your reading this grow a concinse and give it back! so we all can benefit!
