Indigent
About Indigent
  • Birthday 06/05/1983
    90XE Black&Gray Two Tone. My baby. 91 XE Red. My own personal Junkyard. 95XE Gray ...for the wife... Used to have a 1990 R3m TD27T Terrano in Japan.
    Skilled/Experienced Mechanic
    XE
Contact Methods
  • Website URL
    http://
  • ICQ
    Yakima, WA
  • Interests
    My Pathies, Guitar, and fixing anything that is broken.
4,163 profile views
Indigent's Achievements
NPORA Fulltime Resident (4/5)
  1. I'll take one, I have the hard copy, but I love me some PDFs. PM me the info!
  2. I was waiting for this to get asked, and am kind of surprised that it wasn't the first question. How much money are you into it for? I know you have a bunch of things available to you that most people don't. I have access to or own everything i would need, so I am curious. I have been tossing ideas like this around in my head for a bit. Seeing this gets me motivated! Thanks for documenting and sharing!
  3. Buy a can of MAF cleaner and clean your MAF. And as mentioned multiple times, check your compression. Should be around 160 i think, and no more than 14 psi difference between any two adjacent cylinders; meaning 2 and 4 should be within 14 of each other, if not then you have a bad head gasket. Rings, head gasket, or valves not seating will cause leakage that robs you of that explosive power mentioned. If the motor is solid, then you may have bands wearing out in the transmission. Some of that material will be caught by the pan magnet and the brass will not. Drop your trans pan and clean off the magnet so it has a chance to pick up more crap. Also, it is a good idea to install a trans fluid filter.
  4. Kinda hard to believe that no one responded to this. That looks to me to be the wire for the horn. Does your horn work?
  5. I am kinda surprised that no one brought this up, so I will. The #5 injector is not under the plenum... Hope you didn't go through all that for the wrong injector. Also, from what you described, the part you are looking for is called CAP-RUBBER 16619-53J00 in FAST. Those don't feel like rubber to me though, the feel aluminum. Check this pic. Nissan Parts Zone has them for around $3.50 right now. The number I think you are talking about is 17521H (the H kinda looks like a K, but it's an H). That pic is in section 164, under "B Fuel and Engine Control"
  6. Adamzan is right. The terrano I had in Japan had an extra washer fluid tank, pump and lines. The jets were the same ones used to wash windshield. It was pretty neat. Shouldn't be too hard to add a pump and lines whatnot.
  7. if your spark plug gap is way off that might cause what you are seeing. I would pull the problem plugs and check if the gap is either too much or if they are even touching.
  8. The RE4R01A transmission is the same no matter what rig it was in. That includes the pathfinder, terrano, skyline gts-t, 300zx, etc etc etc. The only difference was the bellhousing, which unbolts in a matter of minutes. As long as it is an RE4R01A transmission, and you have the right bellhousing there will be no problems.
  9. Check the thickness of your rotors too. They may look ok, but might be too thin. I believe it is 200mm minimum, and like 260mm new. I had similar problems for a while. I went through every damned brake part BUT the rotors. I went and grabbed my $20 measuring caliper and sure enough, they were like 192mm. Let's face it, they are the last part anyone really wants to change because they are kindof a PITA to even remove. What happens is if they are too worn, the bulk of the brake fluid goes to those calipers and there isn't enough to spread all the way around, allowing your pedal to travel farther. Do yourself a favor and spend a few minutes checking that before you get too far into it.
  10. OK, so there is a bunch of chatter here, and I have one last question about this issue, as I need a VSS currently. I am also looking at the ~$50 option from ebay, and noticed the lack of plastic gear on the shaft of the sensor. Am I correct in thinking that you bought a genuine Nissan gear that worked? Because as stated above, the bladed shaft looks different from the splined shaft in my hands.
  11. they have different part numbers in the Nissan FAST parts system. Other than that, I do not know about physical differences. They can't be all that different because the mounts and bellhousing haven't changed, and neither has the engine block. hope that helps
  12. Indigent
    RPM Problem
    Just to say it, since no one else wants to, Mass Air Flow sensor. It is either the wiring or the sensor itself. To me, it sounds like sensor because of the way it fails later.
  13. It means that that is what the guy on the other end of the phone said. He could not look up the eligibility or other pertinent information relating to my vehicles because they were manufactured prior to the 2002 model year. I put a call in to 1800NISSAN1 and they even had problems. They stated that my vehicle information for both my 91 and my 90 were "archived" and would have to be put back into the system. I have to give them about 24 hours and by then, they should have had enough time to get my VINs back out of archive. Strangely enough, they had no problem with my 95.
  14. Strange, I called my dealer and they said that the farthest back they could go in their system was 2002. I will have to call the nissan 1800 number to get the warranty info. and kind of a funny note, the auto spellchecker deal thinks "nissan" is spelled wrong LOL.
  15. Better yet, take a picture of the cover, and I will translate it for you. That way you know it is right for your rig.
