SaKaNa
About SaKaNa
- Birthday 01/15/1987
1997 Nissan Pathfinder XE
16-21
1997
Contact Methods
AIM
FishNET3000
MSN
bellingdm@verizon.net
Website URL
http://
ICQ
177894559
Yahoo
fishnet650
Philadelphia
SaKaNa's Achievements
NPORA Fulltime Resident (4/5)
Again, I'm no expert, but I'm not aware of any engine mods that will change shift points, but changing tires to a larger size will, as explained above.
Clearance maybe, not sure. Tranny should only be affected by changing tires on an automatic since it doesnt know when to shift, in a manual you know when to.
I'm far from an expert, but from my understanding, the CVs are the tiny links that drive the front wheels from the front differential when you're in 4x4. When you're not in 4x4, they still rotate with the front wheels unless you've installed manual hubs, which prevent the premature wear of the CVs. If you look under your unlifted truck, they should be pretty much straight from the differential to the front wheels. When you've got a suspension lift installed, the CVs are at an angle, facing down somewhat. When strut spacers are installed, they make this angle even more significant, and its easier to break the CVs when you fully extend your suspension. The more lift, the more the angle, the easier it is to cause damage.
So I can just ease off the gas to allow gear changes and I'm not going to fry anything internal? I was worrying that the transmission was on its last leg when it was taking so long... But this is a real relief!
I was thinking the same thing as kmgar99, can you reset the trans comp to allow a relearn so it does it earlier? I was considering just leaving my battery unplugged overnight, but I know I'll forget and have no idea why its not starting. I just had someone do the upper and lower rear bushings today, and I've gotta say, driving feels so much more safe and stable now, my Pathy is as sure-footed as a mountain goat.
I've been experiencing *extremely* long shifts for some time now, to the point that you basically NEED to ease off the gas to let it shift, otherwise its going to stay in gear revving forever, and while my mechanic is pressing out my old bushings and putting in new ones, I told him to take a look at it, he said the transmission is fine, and he suspects the extremely extended shifts are from going 235 to 265 tires... Does this sound right to anyone? Is there a way to do anything about this other than a regear?
Interesting, so I'm not alone.... Just to add to the problems on Rocky Road, I ordered the trim packers on June 15. They never showed up, I never was charged, so I figured I typed my Visa card number wrong (since I go from memory when I type it online). August 23 rolls around and they decide to process my order. An entire sixty nine days later. I call to cancel the order, outraged that any company would find this acceptable, and of course, even during their business hours, their 800 number rings endlessly. Of course their unaccessable 800 numbre is only "accessable" during hours that I'm supposed to be working, so it was a total waste of a day trying to get these guys on the phone... After some time of trying to get through, someone finally answers and cancels the order and does a reversal on the charge.... Seriously, 69 days? Am I the only one who sees a problem here? They never contacted me to say they're on backorder or anything, then just out of nowhere decide to charge me for stuff I ordered and lost interest in MONTHS ago. Hey, I have a brilliant idea, how about tomorrow I go to work and put one of my associate's files in my bottom drawer, and then eventually get around to going through it in November... Oh wait, then I'd get fired, and if everyone at my office did that, we wouldnt do any business. I dont know about any of you guys, but I for one wont be giving them *my* business ever again.
Glen Mills is *far*. I talked to the guy who owns a body shop and he told me to go to a place on Rt73 here in NJ and tell them that he refered me to them, and they'll do it fairly cheap.
Well, you'd think that if I know someone who owns a body shop, that asking him to do it would mean getting a decent price, instead of getting ripped off just to put some plastic on glass.
Where would I look at for professionally doing it? I couldnt imagine my mechanic doing it, but I know a guy who owns a body shop... should I see what kind of deal I can get from him?
OK. Retarded question, but how do I go about taking the glass windows out of my R50? I plan on getting some el-cheapo window tint from walmart, and when I saw the results my friend got when he tried to just stick it on his windows, I couldnt believe how ****** it looked... I figure that I can get much better results if I actually remove the entire window, set it on the floor on a blanket, and put the sticky dark plastic on ALOT better that way. ...so how do I get these things out?
That gear is down at the far end of the transmission, I think its technically the transfer case. Mine went on and off for a while before it completely stopped... Sometimes it'd swing up to like 40mph when I was doing 85 on a highway, sometimes it'd bounce up and down between 0 and 5 or so, but my OBDii reader was giving me a speed if I drove around with it connected, so I figured it was the gauges themselves. $150 for a new cluster and still nothing. So then I got tired of the situation and just got a TomTom soley for the purpose of knowing how fast im going when theres a cop around, though I've started using it for alot more than that. Then I figured it must be the speed sensor itself, since my OBDii computer stopped giving a speed reeading and started giving a VEHICLE SPEED SENSOR failure code. After I replaced the speed sensor for $192 it worked for a few minutes... literally "around the block" then stopped. *FINALLY* my mechanic was doing an oil change and decided to take a look, replaced that gear, everythings fine.
I havent, I was looking around here for that topic today, wondered where my sticker is!
I tried forever to figure out what was wrong with my R50's speedometer. Replaced the whole cluster, the cable, the speed sensor. Finally I find out it was this tiny worn away plastic gear. The little bag it came in says "PINION SPEEDO" on it.
I had a knocking noise from the front passenger side untill I got lifted, so I figure I had a loose strut or something.. Now my problem is that sometimes (especially hot days I notice it the most) I'll go through a turn, and it feels like the rear axle is disconnected or something, I get this weird swing through the turn.
