AlumniCU
Everything posted by AlumniCU
  1. They make one that specifically fits stock, but with the lift I suspect you need to have a longer extension? My challenge is getting the exact shock part number - I believe the Rancho rs9000 is the rs99010 (thx Dean). What would in be for Bilstien or Rancho 5000? I just need to order the parts!!!
  2. Installed my Warn hubs yesterday. Have recommendations for Bilstein 7100 and Rancho RS9000 (RS99010) (do like the adjustability). Any other thoughts? To drop the rear axle to get the springs on, any advice dealing with cables, brakelines and tubes? Any good strategies on how to? The front GR-2 struts will be done by a shop unless one of you in Colorado wants to play (case of beer?). Would save me money for some skid plates...
  3. Yes, wouldn't try to do anything beyond 31 without new wheels with appropriate backspacing. Thanks for your responses and suggestions. Will check t out.
  4. Did these fit without modification? Is there a part number - the Bilstein online application docs aren't much help?
  5. I'm collecting parts to rebuild the suspension of the 97 Pathy SE. It's not a daily driver but for snow and the Rockies. Here's a rundown, with questions... By biggest challenge is part numbers for rear shocks that will work with 2" AC lift, and what OEM strut mounting parts I need to order. Tires, wheels and hubs - - Tires are in good shape - Keeping 15x7 stock Pathy SE rims for now (or could get new wheels) - Warn Premium Manual Locking Hubs (have received) Questions - I'm undecided about 31" on stock rims or going a little larger with new wheels and 32" - Any suggestions for wheels, and what size (should I just go ahead and look at 15X8 or other size with appropriate backspacing for 32") - Would you get 32" over 31"? Front suspension - - AC springs for 2” lift (have received) - AC Camber Alignment Kit (have received) - KYB GR-2 struts (will order) - OEM strut tower mounts (will order) Questions - What specific OEM parts do I need for the strut mounts/bearings? Rear suspension - - NEED shock recommendation with part numbers - Rancho 9000XL? RSX? 5000? BILSTIEN??? - Need to fix death wobble - will get OEM replacement lower arms or AC poly bushings, bolts Questions - - 9000XL vs. RS5000 vs. RSX vs. BILSTIEN???? - WHICH PART NUMBERS WITH THE AC 2" LIFT??????????????? IS THERE ANYTHING ELSE I'M MISSING? I'd appreciate any thoughts AlumniCU
