01Pathy3.5LE
About 01Pathy3.5LE
  • Birthday 07/26/1976
    2001 Black Pathfinder 3.5 LE 255/65/R16 Yokahama Geolander
    Rarely Go Off-Road
Contact Methods
  • Website URL
    http://
  • ICQ
4,809 profile views
01Pathy3.5LE's Achievements
NPORA Regular (2/5)
  1. I am getting a code about the o2 sensor being bad. Question, if I replace the o2 sensor myself, do I need to take the truck to the dealer to reprogram cpu? I wasn't sure if there was anything I need to do to make sure it runs correctly after the fix. Thanks!
  2. Thats a great idea. Anyone else have any luck doing this same type of install?
  3. Hey Everyone. Haven't posted in a while so I thought I would. My Pathy is at 115k and I have a CEL on. Looks like a bad o2 sensor. Question is, Should I replace all o2 sensors due to age of vehicle and mileage, or just what the codes read as the bad ones. I am going to be replacing plugs and wires as well, just curious on your thoughts about the o2 sensors. Thanks!
  4. Just an update. 6 weeks after the change (and some friggin' cold weather too) the Maxima MAF is working in the Pathy like a champ. Big thanks from my wallet and my truck go out to you guys!!!
  5. Just hit 104k on my 01 LE. What maint. would you suggest doing? Just switched the MAF (with the maxima maf 88 told us about. :bow: Worked great!!!) and now i'm looking to keep her going as long as possible. Fluid flushes? Plugs and wires? Belts and pulleys? I need to do this in stages due to a new job and lack of funds. I'm looking for a list of "I would definately do this first. Then I would do this." I appreciate the help!
  6. I just did this fix today. Truck started right up and no problems so far. Thanks 88! I'll let you know how things are going in a few days.
  7. Anyone know if you would need to reprogram the ecm once this switch is made, or is it plug and play?
  8. 88, your timing is impecable!! I believe you just saved me about $300.00. Thank You!!! :bow:
  9. Cleaned it with electronic contact cleaner. Cleaned the air box and it's still spitting and kicking at 2500 rpm. I guess it's time to replace. :sniff:
  10. With the 2001 being a timing chain (right?), is it still the magic 100k mile marker for a timing chain change, or are they good for a longer amount of time?
  11. Thanks everyone for the help. I guess I know what I'm doing tonight. I'll let you know how it goes.
  12. How do I reset the ECM once I clean it/replace it? Also, I'm concerned about the mesh screen inside the air box. Do I need to be aware of anything? Can I clean it with the contact cleaner also?
  13. 88, I checked the harness, it was tight. Just for good measure, I removed it again and re-applied it. No luck. Great suggestion though.
