jaca
    Stock 95' XE (5 speed stick),200.000km do only lite off roading,like to do maintenace myself,so far changed timing belt and oxygen sensor only,rutine brake job and oil changes.Runs great.
    Rarely Go Off-Road
jaca's Achievements
  1. Yeah ,thats timing. had same issue when did my timing.had to go back there again and move camshaft sprocket just one tooth. Came back strong and fast!!! Good luck
  2. My oil in rear differencial (i think remebering LSD sticker),front axel,transfer case,and manual 5 speed transmition,had been changed like 100.000 miles ago . I own 95'XE could somebody advise me on my best choices for oils and grades. THNKS
  3. I think some of proplems with rustin frame especialy in that place ( obove axle) is those holes on side frame .Mud easly gets inside frame thru those holes and keep moistre inside frame.I pluged those side holes with plustic caps on my pathy .There is many weeping holes at bottom frame,plus frame is open at end.
  4. http://www.filterpower.co.uk/universal/kn_tapered_clamp.htm
  5. http://www.filterpower.co.uk/universal/kn_...clamp.htm#order got it ,opening is 4'' .In case somebody need it...
  6. thnks i'll do it .Just would be easer to have right part when you start project ,espacially if this is your only car...
  7. I ment K&N RU2520 from Jim's project something you use insead box (cone). In store thay dont have it under this number ,keep asking for aplication!!!??? does anybody know?
  8. Trying to find this K&N filter but have problem finding it in part stores,by numer RU-2520 .Maby in Canada they use different part no. If somebody who has it ,and remembers opening diameter and lenght and could provide those i would appreciate. THNKS
  9. Thnks ,You PEOPLE ale very helpful.These ideas are worth a millions. I was wondering if there is more ,and how to log in to Jim's instructions ,i dont know by subject.... good day jaca
  10. Thnks SW ,I'll get a book .Do they have exploded view there.This usely helps with many little things.Do i need special plyers to remove this clip holding everythig there . I know rotors not supposed be warped,they just do with time and heat. Thats what was hapening in my prievious cars.This is not big warp but you feel it while brake.Im suppraised this aint happing with pathy ,thats what i notice. Thanks again SW.
  11. Could somebody advise me on changin rotors ,I started ones but got as far as removing hex bolts from hub and then was not sure if sould continue on my own. Do i need special tools ? is it hard to to on driveway?(have air compessor and tools). Pathy is first car/truck i have which rotors does not warp ( do not feel pulsing when braking).They're just worn, i know need to be changed.What is best brand and source (price)to buy rotors??? thks for any help jaca
