About speedbuggy67
- Birthday 02/07/1979
2006 Frontier LE Crew Cab, Bilstein 5100,5125, PRG lift 2inf/1.5r, deck plate mod, axle vent mod. 92 SE pathy 238k miles (sold to family member 1/2013) JGC coils cranked torsen bars hella lighting fogs/driving undercarriage rock lights 31in Grabber at2's idler arm brace SAVE PARAGON www.paragonap.com
30-35
Rarely Go Off-Road
1992
Contact Methods
AIM
aspeedbuggy67
Website URL
http://
ICQ
Gender
brick, NJ
speedbuggy67's Achievements
NPORA Veteran (3/5)
Thanks for the info, when i crawled under to do the rear diff vent mod i was shocked to see no skids on the gas tank.... i mean shouldn't all 4wd trucks have skids wtf.... should be fairly cheap to find nismo skids somewhere maybe ebay. Heck even my ordered new from japan 02 wrx has a rear diff skidplate! From what i understand the fuel sender was done at a recall/tsb from the prior owner. Hopefully it doesn't go out again. My buddies 05 nismo went one under 50k miles and he has 186 on it now and on the same sender. I gotta say no question in my mind i'd rather have my 92 pathfinder on a trail over the frontier.... totally different feel. Scott
About 2 weeks ago i spoke to greg and ordered his 1.5 rear block and bilstein 5125 rear shocks from him, camber bolts and new "top hats" for the bilstein 5100 i got from a clubfrontier member with only 10k miles on them along with xterra front springs. Im hoping to put together the 5100 set at the 2 inch lift with xterra springs and the new top hats and basically swapout my stock fronts for these. My only problem i forsee is getting camber bolts in, more then likely i'll have to get new lower control arms since the stock non adj bolts freeze up in there. maybe i should become a memeber of thenewx.com My best friend has been running a prg rear setup and stillen front spacers since 06 with no problems. I've heard nothing but great things about great at PRG. Any advice and i'm all ears... BTW more then likely i'll keep the 31's on the truck since they are new and upgrade to 32's or 33's down the road...
nice bug!, i get all my parts from california, orange county. IN NJ emissions and inspection don't exist for anything over 25yrs old if you get historic plates. I wish i had more time to work on my bug, they always need something. not even sure what i could get for the 79 epiogue, when the market was better im sure 15+k was realistic but now is even 10 something to aim for? Scott
Yes my 92 pathfinder is a SE, the frontier is a LE. Funny you mention the seals i already changed the oem diff breather and ran a 5/16 fuel line up to the taillight ending in a fuel filter to keep the air clean and not pressurize the diff like stock frontiers sometimes do. The frontier has open diffs and firestone destination LE's and i can't belive how aweful the traction is compared to the pathfinder with factory LSD and grabber at2's. THe timing chain on the fronty alreay wore through the guides and will soon be getting changed something all the 4.0's have to deal with as mileage increases. Sounds supercharged right now. Lastly i have the new radiator and bypassed the factory cooler in the rad and only use the external factory cooler. I think i covered all their flaws hopefully things will be smooth. Just debating the PRG lift or bilstein 5100's for the front and probably prg blocks for the rear. Not sure what size tires the fronty is going to get maybe "33's" or "32's"..... 285 are the common upgrade on 2nd gen frontiers. So far still learning..... and learning not much aftermarket support.... try to find a front bumper lightbar other then the westin bullbar crap or a reg brushguard...sigh.. Scott
THe forum was a big help, got some parts, even a 95xe parts truck aong the way. Put the JGC coils in, cranked torsion bars, even trans issues i had from day 1, but replaced with the lower mileage 95 transmission. My problem is i have a car addiction, 6 cars between my wife and i since i got the frontier something has to go. Wrx is the daily driver since april 2001, mint mint 86 celicasupra, 67 vw i redid from the ground up, the pathfinder, the frontier and "the wifes suv". I opened last months motor trend and there was an article about pathfinders and a 87 red was in the article and picture, made me feel even worse to get rid of the pathy. I have a 9 month old son and know the frontier should be safer too with airbags, abs that works, and child seat anchors and no rust on the frame. I have tons of spare parts and still will be around, just with a different ride...
This forum has been so helpful over the years (over 7yrs for me) and i can honestly say i find it hard to believe i'll ever own a vehicle as reliable as my 92 pathfinder SE but its time i have to move onto something newer. A neighbor (77yr old) was practically giving away his 2006 frontier LE crew cab 4x4 with 174k miles on it and had to jump on it. It had the dreaded trans/radiator contamination issue which i flushed and is fixed since i cought it early. he bought a 2012 frontier sv crew cab to replace this current one. My pathfinder seemed to only need tires, brakes, and oil changes since i owned it EXCEPT for frame rust which was welded up twice, the last time was 2yrs ago and reboxed and done right (athough visualy not beautiful welds) and has 238k miles on her. Doesn't leak or burn anything!!! I just hope this frontier will be close to as reliable. The pathfinder got me through the dreaded NJ Sandy Hurricane, bumper deep in water, surviving when half my neighbors lost their cars ( i live a mile and ahalf from the ocean) even made a rescue of a family. It kills me to part with it but we all have to part with them at some point. My brohter in law has a 93 which he might sell and buy my 92 since i have more mods and brand new tires etc etc so it will live on in the family. Thanks to all of you the last 7+yrs..... i'll probably have the truck the next month or two or until he sells his 93 SE pathfinder. Sad day indeed! I'll continue on clubfrontier.... Scott
i feel your pain on the rust, just repaired mine, trust/rusty trucks they are. I debated totally cutting and putting new boxed frame in its place but cut and patches for now. Good luck with it. Just curious where did you get hose headlights they look great were they a good lighting upgrade? Sharp. Scott
I have been planning to do this mod for years but finally did it since i was picking up 4 31in tires out of state and wasn't sure they were going to fit. Im sure we've all would have liked to be able to remove the back seat bottoms for an extra foot of room in the back when folding the seats down. Well i went to harbor freight and bought these quick release pins which couldn't have fit better and were about 2.50 a peice and i needed 4 of them. I used a grinder to get the orig hinge pins out and these fit right into place and removal takes seconds and replacment maybe a minute a piece since you have to line the hinges up. Well worth it for under 10 bucks. Here is a picture of the part and the installation on the seat bottom. Hopefully this will help someone out. YOu won't be able to use the black plastic hinge cover unless you mod them. Good luck, if questions let me know... ps for those curious just got new General Grabber AT2's reviews put them higher then BFG at's at a fraction of the price, even tirerack has them for 132 i think bfg at's are 35+ more a tire and i like this tread pattern more (and i was a hard core BFGat guy!) I love mud tires but with gas prices i'd rather have the 2+mpg more with at's.
stalker 94 pathfinder project...pics
speedbuggy67 replied to stalker's topic in 90-95 WD21 Pathfinders
THe vw, the karmann badge were on them until "1980" or officially 79 models. Those wheels aren't orig,maybe JC whitney???APpears to have rubber caps on the bumper so that'd make it 74-79 vert. I'm gonna go on a limb say the rest looks something like this one.... btw nice work on the pathfinder! Scott -
seems this with the economy everyone is looking for more economical answers with tires. I'm still amazed how many people rave about the falken wild peaks, and they look like street tires. What ever happened to the days of guys running super swampers or ground hawgs. Duratracs weigh in what most all terrains or even street tires weigh and they're pretty aggressive compared to an AT. I'm still skeptical on wild peaks but they're cheap esp on vulcantire.com ROughly 30 bucks less a tire less then the duratracs though. Scott
