weight weenie
    1990 Terrano TD27 turbo-diesel AT , ARB bull-bar bumper, 110k km, Nokian studs (winter). Yes, my Pathy is RHD.
    Screwdriver Mechanic
Contact Methods
  • Website URL
    http://
  • ICQ
    AB Canada
  • Interests
    Mountain roads to drive up,mountain trails (singletrack} to ride my mountain bike down.
weight weenie's Achievements
  1. weight weenie
    RPMs meter
    Hi all! I'm not sure if a '97 could have the same problem with the tach, but all you '95 & older owners may experience something like I have. My '90 Terrano ( it's an rhd pathy with a 2.7 turbo-diesel, as Canada allows 15-yr olds from overseas to be imported ) has the same sticking needle thing described by Bear claw. I took my cluster lens off to discover that years of sun & heat had warped the needle so that the tip was dragging on the guage face, leaving a light rub mark on the outer perimeter of the tach face. A temporary solution was to simply bend it back with my fingers, which worked for a short while but didn't last. I then overzealously snapped it off on the 2nd attempt, forcing me to the wreckers yard for a suitable replacement. Anyway, that's my windy story for today.
  2. Pathys don't have gutter rails like Land Cruisers and Rover Discos, but does that mean it's impossible to put 1,500 lbs on the roof like those other guys can? A roof-top tent etc. is what I have in mind. Does anyone know of a roof rack mounting system compatible with Pathfinders that can handle substantially more than the 300 lb. limit of Yakima brackets? A local rack shop guy told me I'd have to get one custom made, and even then.....
  3. Thanks for the replies. I do like the camera idea and will price it out.
  4. of course we're trying tosplit hairs a bit , but pathy's weigh 3795 lbs and epa rates them @ 18 mpg hwy. ford explorers tip the scales @ 3915 lbs but get 20 hwy. I was just wondering if anyone knew what might explain this . I suppose it might just be that with a 4.0 litre the explorer is slightly less underpowered stock, but that's easily rectified. I only thought of the hubs because the old chev 4x4's with solid axle leaf spring susp. and manual hubs got noticeably better fuel mileage than their auto hub counterparts in the late '80's-early 90's
  5. Does anyone know if the reason pathfinders don't get the fuel economy you might expect from a vehicle of it's size and weight is because of the automatic hubs, and can they easily be changed to a Warn or similar manual locking hub ?
  6. Only a little easier, I think....Anyway to have a whole truck w/55k kms on it and rust-free are advantages I would prefer to keep if I can. I have a donor truck here for the dash and steering parts, and nissan, unlike toyota, keeps the t-case shifter and front axle offset the same in both markets, so I'm pretty sure it's at least possible , unless we're missing something......
  7. hi everyone. I recently bought a '90 pathy because I like the size, wheelbase, weight,etc. Then I came across this terrano thing with a quite reputable td27 turbo diesel yielding similar torque but twice the fuel economy. Only thing is, only in rhd (right hand drive, meaning the steering wheel is on the way wrong side if you EVER want to pull out and pass that 5mph dump truck. I've spoken with a few mechanics who think an rhd-lhd conversion might be the better choice since they (terranos) tend to be clean and low-milers. Has anyone attempted this- any insights would be appreciated. Thanks.
