shane
Everything posted by shane
  1. whats a good kind of a high flow cat for my 90 pathfinder i want to get one but i have no idea what to get
  2. i see how are tires better with a lower tire pressure
  3. and also i know this is a bit off topic but i dont want to start a new topic for this question. what psi should i put in my BF goodrich km2s they are 31-10.5 I ushally have them at 35 and drop them to 25 on the trail but i have a small toe due to my torchen bar being cranked up i was concidering bringing to 28 psi for the road and trails. What do you guys think would be a good psi?
  4. ok thank you guys and what size pipe do you think would be the best ?
  5. lol no im saying anything anything better then ming are high pro, 6 soda cans a coat hanger and a rubber band would put my cracked headers to shame lol
  6. i was going for pacesetter
  7. hmmm well when i get a chance i wanted to redo the entire exhust system with new hig pro headers,high flow cat, delta flow 40 series and split the pipe after the muffler and run two back and all with a 2 1/4 pipe i don't have the money for all that now and i wanted to make my truck sound nicer without spending alot of money cause im going to need a new clutch pretty soon, im thinking about geting a high flow cat now and put it on, then when i redo the whole system i will just keep the high flow cat and add it to the system. what do you guys think? and edicer2, do you have a sound clip of what yours sounds like adamzan, your pathy sounds nice, you said it has no cat with stock muffler or somthing else
  8. hmmm well when i get a chance i wanted to redo the entire exhust system with new hig pro headers,high flow cat, delta flow 40 series and split the pipe after the muffler and run two back and all with a 2 1/4 pipe i don't have the money for all that now and i wanted to make my truck sound nicer without spending alot of money cause im going to need a new clutch pretty soon, im thinking about geting a high flow cat now and put it on, then when i redo the whole system i will just keep the high flow cat and add it to the system. what do you guys think? and edicer2, do you have a sound clip of what yours sounds like adamzan, your pathy sounds nice, you said it has no cat with stock muffler or somthing else
  9. hey guys i have a 90 pathfinder 3.0 with a flowmaster 40 series and the stock cat is holding it back i want to take off the cat at run a straight pipe that is removable so i can put the cat back on for emmisions to the flowmaster, any suggestions? has anyone tried this yet and how did it sound? will i get more horsepower? Should i run a bigger pipe or keep it regular size? or is this just a stupid idea?
  10. were you happy with the body lift? any problems pros or cons?
  11. hmm i think im going to stick with 31s and instead of 10.5 im going to try and get 11.5 cause i dont want to cut the fenders
  12. i just replaced all my tie rods and the cross bar. and im going to have to cut the fender for the 32s to fit and do a body lift witch iv never done any idea how?
  13. how bad do the 33s slow you down? and that one inch from 32 to 33 slows it down?
  14. damn it i tryed so much to raise it i cranked up the tork bar put spacers in the back coils, replaced the shock absorbers with bigger f-150 absorbers and put on 31/10.5 i think im going to do a 2 or 3 inch body lift and get 32/11.5 is there anything i should know befor i do the body lift or get the 32s
  15. and do you know the stock ground clearance of a 90-95 pathy?
  16. i just measured it and ground to frame is 15in and the body is 18in is that good? i don't know stock ground clearance so i dont know how much its lifted
  17. i hope so to, from what you say the 33s sound like they will slow me down alot but the 32s seem to be just right i just hope i can fit them with out cuting
  18. well i have a 8 inch rim with a 1 inch offset would that be good enough for 11.5?
  19. what do you think would be best 31/10.5, 32/11.5 or 33 the 31s are on now and there nice but i want to try and get one more inch on there when i go and get my bfg km2s
  20. so i can put the 32/11.5 on you said i have to bring it up and i was wondering if it had to be suspension or body
