notorious7004
    1993 XEV6 4x4
    Serious Off Road Enthusiast
notorious7004's Achievements
  1. I would suspect worn valve guides/seals. They let oild drip to the cylinders and you get the white / blueish smoke when you initially start up.
  2. I have 6x9 Xplods on my '93 and had them wired thru the factory amps with the stock radio. The sound was horrible. I´ve since installed a Pioneer CD/radio with high power amp and discarded the factory amps. 100% improvement! My recommendation is to get rid of the factory amps, they put out like 6 watts anyway.
  3. I recently installed a roof carrier made by Con-Fer in California. I purchased it from 4x4 products which I found through the links here at this club. It comes disassmbled but it´s fairly easy to install; the only "drawback" is having to drill 12 - 1/2" holes in the roof, since my 93 XE did not come with factory rails. But the system uses rubber "plugs" that swell from the inside when tightened. So far no leaks. It also comes without a floor but I will be bolting some wire mesh soon. Looks great and it´s a great platform for off-road lights. Good luck!
