neri33
    pathfinder 88, custom bumper, roof rack and working in fog lamp
    Rarely Go Off-Road
neri33's Achievements
  1. Harbinger: I like a lot the xterra but to spence to me, the roof rack always like it and design same model for pathfinder pic1 machined brackets with basket unccpathfinder: if you use solidworks or pro-e software, I can send you the files to simulate in your computer Filthy Luker: the back bumper is more large than stock, I cut 3" of original design for better angle, and put JGC coils and custom base to avoid cut pigtail and I have 4" lift on back, the holes are for fog lamp but I have a problem with transmision to connect it when put reverse. detail light transworldmoto: I can't help with the construction of this, I don't know weld, but the cost is aroun 400 dlls plus ship, if you know weld or there is a shop near your location, I can send you the blue print, i think the cost is same but you save the shiping and add some modification.
  2. yes it is i take the model from jp's and adjust to my path because the front on path is not flat (i think in hb no flat to). i have more details bumper (front and back) for construction regarding my experience when made it the back bumper is just my design, (I don't saw other like my back bumper)
  3. hello, send me a e-mail, i have the blue print for front bumper. My mail is neri_genaro@hotmail.com
  4. installing warm premium manual hubs this is the link
  5. hello all, i saw the procedure to change from automatic to manual locking hubs, but what's up with the lock washer?. for the automatic this lock washer is on inside slot, for manual, it is necesary? i changed automatic to manual locking hubs but the mechanic put the washer on outside slot, it is correct? thanks
  6. somebody know how make a connection the MSD 6AL module? we put on the Pathfinder 88 but the rpm no work, we connect again without MSD and rpm work fine. if you have a suggestion, please let us know thanks
  7. one more question what is a good front shocks to use with UCA for 3" lift front? I have a rancho rs5000 #9116 rear with the JGC coils without cut pigtal with custom bases and I want to update front suspension thanks
  8. thanks 88pathoffroad tomorrow I will go with the mechanic to make the diagnostic as you mentioned. I forget to mention that the truck is standar
