shadylurker
Everything posted by shadylurker
  1. how much of a PITA is the seal to change?
  2. Thanks all it is fixed! it has the stock amps, I really do need to re wire it now, oh well gives me an excuse to put in my old 900w amp and sub thanks for the help
  3. Problem: Stereo comes on but no sound at all comes out Ok, replaced an old pioneer head unit with a new pioneer head unit, re spliced into the old aftermarket harness adapter, im 99% positive my wires are 100% correct. I even got a multi meter out and ohm tested the speakers from the new head unit harness they all read 3 ohms, I was so confident i did it right i went and replaced the head unit with another new one....Same problem i fiddled with settings. now i am out of ideas. Bestow your knowledge upon me NPORA i am almost thinking i should go get another new one again. :coffee!:
  4. awesome thank you for the reply
  5. First off I am separated from my pathfinder at the moment because of the military, and I will be back with it shortly, so if my questions seem obvious it's because i cant see the truck or tinker on it 1. I'm getting a Check engine light, the code it is throwing is about the EGR system, could this be because both of my manifolds leak so its not getting the right pressure? it is intermittent 2. (here is the obvious question) what is the bolt pattern, and offset of the rims, I have some 31" tires waiting to go on and would like to get some new steelies 3. I timed it in a rush before I left and i had to put the distributor all the way to its max ( i cant remember which way) for it to read the right timing, Could this be a problem related to my EGR light? 4. Feels way down on power for a 3.0l v6 but then again it doesnt have much to start with is this probably a mixture of #1 and #3? 5. last but not least, how long does the vg30e last? I replaced the water pump but I remember it still slowly loosing coolant, no white smoke, ect. So im wondering if i have a slow head gasket leak or something, I'm still debating on tearing the engine all the way out and just replacing all the seals, gaskets, and known problem areas. Thanks ahead of time for answers -Travis
  6. My 1995 pathy v6 manual is displaying an EGR code, is there a known fix for this?
