blackspawn
About blackspawn
  • Birthday 09/25/1967
    1990 SE stock Pathfinder
    Rarely Go Off-Road
    SE Offroad
    North Carolina
blackspawn's Achievements
NPORA Fulltime Resident (4/5)
  1. 207,000 no rebuild...and running and cranky!!!!
  2. Seafoam my engine, had a loud lifter ticking. NOT anymore!!! I love SEAFOAM!
  3. Thanks for the info!!!! I'm on the HUNT!
  4. Ok, I'm hearing the HD auto transmission...My question is where is this HD auto transmission coming out of so I can get one for a spare tranny?
  5. Got the same problem, guess I better try Seafoam...
  6. My truck did that once, and I found the wires on the positive side of the battery was kinda loose. One of them was feeding one side of the headlights. I have a 90 Pathy if that helps.
  7. Took out my headlight switch and cleaned out the contacts so it would work properly...
  8. I'm going the buy a new one route,I priced one at AutoZone for $56. Thanks,bro.
  9. I have the exact same problem, driver side high beam not working. This problem just started a couple weeks ago. I can move the headlight switch toggle forward before its in the locked hi beam position and both light are on. I think my problem is a bad headlight switch. What do you guys think?
  10. Wow, thanks guys.. I see this is not a 2-3 hour job.YEAH!!!
  11. The bottom of the truck is always wet also it fall on the exhaust pipe causing it to smoke.
  12. I'm trying to keep this thing till it die,but I'm at that age that if its giving me too much trouble then I get rid of it.
