Trogdor636
Upper Control Poly Bushings
What's up party people? Been forever since I've been here....
I'm installing UCA poly bushings with no good instructions....should the outer lip of the bushing be on the outside of the UCA on both sides? Or should it look as if you used the press in bushings....anybody have a good picture of theirs? Thanks!
Good to hear from you! Sorry I can help you with your issue but I am sure someone will chime in... I was wondering if you moved north or not.
http://www.nicoclub.com/archives/nissan-hardbody-truck-suspension-torsion-bars-bushings.html
It's for a 2wd but the uca are the same.
You do want the flange part on the outside on both sides. It's fairly easy, I was able to push in my poly bushings by hand. Make sure to use a grease made for it or you'll be replacing them again in a short period of time.
Thanks guys, that helped. It seemed like the proper way, Prothane sent me instructions for a leaf spring.....
I did use a ton of their "super grease" I know how noisy my sway bar bushings get....Thanks again.
