ricks99 Posted September 9, 2014 Share Posted September 9, 2014 Cruise control on my 1997 LE stopped working yesterday. When I last used it (about a week ago, it worked fine). The rocker switch does *not* light up when I turn it on. The CRUISE light does *not* light up on my instrument cluster. Clicking SET or ACCELERATE does nothing. I thought it was a simple fuse... but for the life of me (I'm *NOT* a gear head) I could not find any fuse labeled "CRUISE CONTROL" in any of the fuse boxes. Any ideas on where to start looking? Hopefully this is an easy fix? Link to comment Share on other sites More sharing options...
Quaintbucket Posted September 9, 2014 Share Posted September 9, 2014 http://www.nicoclub.com/FSM/Pathfinder/1997_Pathfinder/el.pdf start at page 162. the junction box under your steering wheel column (driver side door, there's a little swing hinge. i use that for my coin storage). It should be #12 (7.5amp) so second column, 3rd row for the fuse. try replacing that first. Link to comment Share on other sites More sharing options...
ricks99 Posted September 9, 2014 Author Share Posted September 9, 2014 It should be #12 (7.5amp) so second column, 3rd row for the fuse. try replacing that first. Nope, fuse looks fine -- not blown. Interesting enough, it is marked as ELEC IGN (which must be Japanese for "Cruise Control" eh?). Thanks for the Electical Control manual (though I'm not sure it will help me very much). The ASCD pump seems intact -- there's no disconnected plugs The ASCD Inhibit relay seems OK (although I don't know if I could tell what a "bad" one looks like). Is there anything a complete novice can try? Link to comment Share on other sites More sharing options...
OfftourRoadie96 Posted September 9, 2014 Share Posted September 9, 2014 Any CEL's ??? Mine, stopped working when it envolved a busted speed sensor (speedometer & odometer stopped working too) Link to comment Share on other sites More sharing options...
Rebelord Posted September 9, 2014 Share Posted September 9, 2014 The cruise control brake switch? There is a rubber plug on the brake pedal that likes to fall apart and out. Can replace the plug, or tape n glue pennies in its place. What I had to do to mine. Link to comment Share on other sites More sharing options...
Quaintbucket Posted September 9, 2014 Share Posted September 9, 2014 Nope, fuse looks fine -- not blown. Interesting enough, it is marked as ELEC IGN (which must be Japanese for "Cruise Control" eh?). ???? Weird. I have to check my pathfinder since we have the same year. Link to comment Share on other sites More sharing options...
theexbrit Posted September 10, 2014 Share Posted September 10, 2014 Mine flashes at me when I switch it on & won't work, so I have to work thru the FSM....... Link to comment Share on other sites More sharing options...
ricks99 Posted September 10, 2014 Author Share Posted September 10, 2014 Any CEL's ???Nope, the Check Engine Light is off. Link to comment Share on other sites More sharing options...
ricks99 Posted September 10, 2014 Author Share Posted September 10, 2014 The cruise control brake switch? There is a rubber plug on the brake pedal that likes to fall apart and out. Can replace the plug, or tape n glue pennies in its place. What I had to do to mine. Maybe... it seems ok to me, but I'm not entirely sure what I should be looking for. Can you post a picture of the pedal and switch? Link to comment Share on other sites More sharing options...
Rebelord Posted September 10, 2014 Share Posted September 10, 2014 Page 162 it shows it in the fsm Sent from my Moto X Link to comment Share on other sites More sharing options...
ricks99 Posted September 12, 2014 Author Share Posted September 12, 2014 Yup, turns out it was the plug/stopper behind the ASCD module (although, the one for the brake looks like is in perfect shape). Looks like this is what I need: http://www.nissanpartszone.com/parts/nissan-rubber-stopper~46584-5p010.html Right? Thanks all! Link to comment Share on other sites More sharing options...
Rebelord Posted September 12, 2014 Share Posted September 12, 2014 Two pennies super glued to each other than super glue em in place. What I did been goos for a year and off road Sent from my Moto X Link to comment Share on other sites More sharing options...
