Guest darrenr Posted July 12, 2006 Share Posted July 12, 2006 Hi all. New to the forum. I've searched for the topic and couldn't find it...so here goes. Have a 97 Pathfinder and I'm trying to install Yakima Q-Towers in the rack runners. How the heck to I remove the end caps off the roof rack so I can slide the Q-Towers in. (And yes, I've loosened the screw but the cap doesn't budge). Is there a secret? Thanks all!! Link to comment Share on other sites More sharing options...
96pfinderSE Posted July 12, 2006 Share Posted July 12, 2006 take the screw out then pull it off. try front and back. i had to pull the back ones. Link to comment Share on other sites More sharing options...
Guest darrenr Posted July 13, 2006 Share Posted July 13, 2006 I took the screw out but the darn thing didn't budge. That's it though? That's all I need to do? Maybe I'll spray some lube of some sort and see what happens. Thanks. :cool2: Link to comment Share on other sites More sharing options...
DJ Dank Posted July 16, 2006 Share Posted July 16, 2006 They are a little tough to remove. You have to pull outwards and up at the same time after you removed the screw(s). Link to comment Share on other sites More sharing options...
