properly switching from 2wd to 4wd!
Guest 96max2fast
Guest 96max2fast
How do you properly switch between 2wd and 4wd. Does the car need to be in Park, neutral or drive? Does it matter? How about 2 and 4 low? Everytime I try to operate it, it grinds before engaging!!! :(
neutral. stopped.
also i believe (not in my truck now) but it is written how to on your sun visor. at least on my 95 it is....and i thought shifting from 2HI to 4HI you kept it in drive, and could shift on the fly at speeds up to 50MPH....either way i always stop, but i thought the only time you had to shift into N was when shifting from 4HI to 4LO....
-sam
