Cuong Nguyen Posted June 30, 2006 Share Posted June 30, 2006 How is the roof rack railings held down? I see the screws but it seems like they're not backing out. I need to fix the rust that's spreading from under the railings :o Link to comment Share on other sites More sharing options...
Precise1 Posted June 30, 2006 Share Posted June 30, 2006 You have threaded inserts in the roof. I bet they are spinning... You may have to pull the hedliner ?? First, try leveraging up so the screw (hence insert) has a load on it and try backing out the screw then. Sometimes you can bind the insert enough to keep it from spinning. B Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted June 30, 2006 Author Share Posted June 30, 2006 I'll give it a try and update you on it! Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted June 30, 2006 Author Share Posted June 30, 2006 stripped the heads of the screws. Yep, those POS inserts are spinning. I'm going to have to dremel/cut the the inserts in order to remove the inserts and rails. I don't think I can get to the rearmost insert. I might have to rip it through the top... Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted June 30, 2006 Author Share Posted June 30, 2006 (edited) Ended up ripping the remost insert out through the top. Dremeled down the insert to where I could pop it through with the hammer. Going to sand down what I can and cover up the rust since a storm is moving in. I'll have to wait until dry weather to work on it again. I've never done body work before so I'm wondering as to how to repair my rust problem. One of the areas is rusted bad. The rust almost ate through the sheetmetal. This this how you do it?: sand/grind the rust until you have is just bare shiny metal make sure you don't touch it the metal after doing so seal it add bondo/putty/filler let it cure sand it smooth paint and wax the poop out of it Edited June 30, 2006 by Cuong Nguyen Link to comment Share on other sites More sharing options...
Pathfinder-jay Posted July 1, 2006 Share Posted July 1, 2006 Grind down all rust to bare metal and surrounding areas( good to have an inch or 2 away from the rust for it usually has alreasy started spreading). Be sure to grind it down with a steel brush found at any local hardware store. Its just an attachement for a grinder -Clean the surface of all grease/dust -Buy a primer (personally I use http://www.zrcworldwide.com/) Id give it 2 coats of primer. ZRC might be expensive but it is the only primer that chemicaly bonds with metal... it is used to paint bridges etc.... and on my dads old car it kept rust away for 15 years... then he scrapped the car (with still no rust and we live in Quebec with bad winters and lots of road salt and humidity in the summer) -If its not completely smooth then you can use sandpaper dunked in water and sand it down and it will come completely smooth -Buy the paint for your truck using the paint code under your hood -Apply 2-3 layers -Buy a clear and apply 2-3 layers of that -Then buff it out Link to comment Share on other sites More sharing options...
Precise1 Posted July 1, 2006 Share Posted July 1, 2006 Sorry, I don't know diddly about body work other than common sense. Sounds like basically the right idea though. Do you plan to reinstall the roof rack ?? You can use jack nuts. 1/4-20 will hold like 300 lbs each and are easy to install. Much to my suprise, Napa autoparts had them and plastic coated also so they don't scratch and seal better. http://www.emhart.com/products/pop/jacknut.asp B Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted July 2, 2006 Author Share Posted July 2, 2006 I suck at using bondo! It dried up on me too quick. Also, it's very runny beforehand and so it went through the holes. Gotta find someone to tack some sheetmetal on or what not. I'm going to have to clean roof again since it's rusting over again due to the rain. Link to comment Share on other sites More sharing options...
Pathfinder-jay Posted July 2, 2006 Share Posted July 2, 2006 could also use fiberglass... Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted July 13, 2006 Author Share Posted July 13, 2006 Well I'm almost done with the botch job. Used a rattle can and didn't realized I picked up the wrong stuff and started spraying. Thought I had picked up the primer... but ended up being paint. oh well. I didn't tape the area off and went at it. Yeah, it looks like crap, but it should keep her from rusting Link to comment Share on other sites More sharing options...
