Cuong Nguyen Posted April 15, 2006 Share Posted April 15, 2006 This is something for those out there who are two wheel drive and looking to convert to 4x4. This is other option to having a front drivetrain of some sort. it would be cheaper and perhaps easier to start off with 4x4 in the beginning but you live and you learn and it's a part of modding and wrenching. You're probably thinking, why not just go with a solid axle swap? Well, some people do not realize how much money is involved in one. You think it's cheap? Not one bit. I know from personal experience. Anyways, you can pick up most of these parts from people who swapped to a solid front axle for relatively cheap if not dirt free. Majority of the swap is mostly bolt except for the front differential. The two wheel drive pathfinders lack the rear frame mounts for the front diffrential crossmember. There are two crossmembers that the front diff sits on and the 2wd has only one--the main one that holds the front suspension together. you're going have to fabricate some mounts/brackets in order to securely mount the front differential. Everything else needed for the swap is basically common sense stuff which I hope all of you have. If not, I highly suggest you pick up a FSM or at least a Chilton's or Haynes or equivilent at the bare minimum. I can do the swap in probably two days by myself with hand tools. One day is pushing it if I started in the morning. As for those who have never tackled such a job. Expect a week at most so make sure you have another vehicle to get around in. What you will need: front differential/axle with corresponding gear ratio to match the rear axle shafts manual hubs--the autos will work fine but you might as well upgrade to the manuals right now front spindle/hub assemblies (optional but recommended: new rotors/turned w/ new brakes) front drive shaft rear one piece drive shaft corrresponding transmission with transfer case shifter assembly and accessories Speedometer cable (?) PB Blaster or similar Jacks 2 set of jack stands Optional but recommended: upper ball joints lower ball joints Lift UCAs Aftermarket torsion bars steering upgrade rear main seal transfer case gear oil Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted April 24, 2006 Author Share Posted April 24, 2006 My 4x4 swap price rough country lift arms 200 lower balljoints 54 upper balljoints 40 inner tie rods 26 outer tie rods 70 Warn Locking hubs 150 Firestone lifetime alignment 150 CV axles 200 SAW torsion bars 190 sway bar disconnects 90 parts pathfinder 700 L&P steering stage 2 355 total: 2225 Bare minimum auto locking hubs 15 CV axles 200 transmission+t-case 500 transmission crossmember 35 spindles 100 front drive shaft 35 rear drive shaft 55 front differential 100 front crossmember 25 total 1065 welding and metal not included as well as tax. the prices vary depending on how cheap you can get the stuff for. Just a ballpark figure. Link to comment Share on other sites More sharing options...
Earth1 Posted April 25, 2006 Share Posted April 25, 2006 Nice writeup! Link to comment Share on other sites More sharing options...
