Guest walt Posted April 11, 2006 Share Posted April 11, 2006 I had a Pathfinder until the other day when starting I drop the thing into gear and the engine went to max RPM. Unfortunately I could not help from hitting a van. Is there anyone who has heard of this problem. I have had the rust repaired in the rear. Plates were welded on the frame $300. Link to comment Share on other sites More sharing options...
TrailChaser Posted April 12, 2006 Share Posted April 12, 2006 Did you floor it then when you let off it stayed floored? That's a pretty common problem. Check the how too's for a quick fix. To bad it's too late. Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 12, 2006 Share Posted April 12, 2006 The only thing that'd do that is the throttle sticking open. No electronic device on the engine will make it rev up to max RPM's. Link to comment Share on other sites More sharing options...
Earth1 Posted April 12, 2006 Share Posted April 12, 2006 Could it be that the cruise control cruise was stuck? Happened to me once, but it was in neutral. Link to comment Share on other sites More sharing options...
fordsho90 Posted April 12, 2006 Share Posted April 12, 2006 click this try this Link to comment Share on other sites More sharing options...
