strykeone Posted April 1, 2006 Share Posted April 1, 2006 87 3.0 v6. Both my front driver side signal light and passenger tail light are out. I pulled and replaced both bulbs with much trouble because of the rust/corrosion in them. The tail light was especially bad (couldn't even see the contact). Neither worked with new bulbs. The tail light is really bad...can I just buy a replacement "plug" (don't know the name) and slap it in? Is there a way to clean it? The signal on the other hand has rust inside, just not nearly as much, I can see the contact but it refuses to work. The other signal works fine. Thanks in advance =) Link to comment Share on other sites More sharing options...
dagwoodzz Posted April 1, 2006 Share Posted April 1, 2006 You might try to scavenge some replacement lights from the JunkYard. The good thing is all fit up thru '92 I think when they changed body style. Contact with the bulb sounds like your problem. If you go by way of junkyard, snag a new light switch too. It's an easy swap and can address the contact issue from both ends. I'm curious did all lights go out a once? Link to comment Share on other sites More sharing options...
strykeone Posted April 1, 2006 Author Share Posted April 1, 2006 No they did not go all out at once, the signal light went the day i put in a new battery, though I doubt that those are related. By light switch do you mean the one on the steering column? Because I've already addressed that issue For the tail light should I replace the whole thing or just the pplug for the light? Link to comment Share on other sites More sharing options...
dagwoodzz Posted April 1, 2006 Share Posted April 1, 2006 For the tail light should I replace the whole thing or just the pplug for the light? I would replace whole thing. I replaced my running lights because they were cracked. I didn't consider trying to salvage covers for that reason. My advice is based off how easy it was to remove them. I have not removed my tail lights but don't think they would be any more difficult. Someone else may need to correct me though Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 2, 2006 Share Posted April 2, 2006 If you can find a taillight in a junkyard, the wiring harness with bulb sockets comes off it with a few screws. Totally swappable. Link to comment Share on other sites More sharing options...
