parking brake mounting bolts
Cuong Nguyen
My parking brake on the rear right side was missing the bolts that hold the line to the back of the mounting plate so I took a bolt out of the left side. Too the point, I snapped the bolt. Would one bolt in be sufficient to hold it in place?
well, they are significant in that they do hold some of the tension when the brake is in use.. for some reason i can't recall this here but there must be a reason for having 2 bolts.. i would guess, for just parking you should be ok unless some serious inclines are involved. as to emergency operations - that's prob. why there are 2 bolts.. take care, i say.
