Guest ReyXLP Posted March 14, 2004 Share Posted March 14, 2004 I've got a 97 SE with about 85k on the clock. I am thinking about switching to synthetic. I am worried about getting leaks -- I've heard after this many miles, with some cars switching to synthetic will result in oil leaks. Anyone have any advice on this? Thanks. Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 15, 2004 Share Posted March 15, 2004 Absolute crap. It's a myth. If an engine starts leaking, it's because the seals are old and shot or it's been abused or overreved, and that's the only reason. It's completely safe to use synthetic oil in your Pathfinder. Your Pathfinder engine probably won't even leak past the 120,000 mile mark. Link to comment Share on other sites More sharing options...
NissanPerson Posted March 15, 2004 Share Posted March 15, 2004 I've got 175K on mine and I use synthetic and I don't have any problems. Link to comment Share on other sites More sharing options...
MatterHorn Posted March 15, 2004 Share Posted March 15, 2004 using sythentic oil likely will just let you know if you have a leak or not ... it doesn't cause leaks ... personally ... I use SAE 30 and every other oil change I use marvel mystery oil for 1 out of the 4 total quarts just to keep things loose... I've had problems with using Quaker State synthetics glazing on engine internals ... although this isn't a SERIOUS problem, it can have adverse affects on bearings and cylinder surfaces ... Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 15, 2004 Share Posted March 15, 2004 How do you know that QS was causing glazing on the internals? Wierd, man. Link to comment Share on other sites More sharing options...
MatterHorn Posted March 17, 2004 Share Posted March 17, 2004 all that I have ever put in it was quaker ... and I changed to oil pan out at about 152k and everything was pretty much clean ... then I tore it all apart after I sheared the Keyway keeper on the crank shaft ... you could see the grime and wear in all the bearing jurnals and bearings them selves ... and I was never one to get a few more miles on an oil change ... I was good about that ... it wasn't like it was a huge problem, but that build up caused about a 1/16 inch of constriction all the way around through the oil system ... the stuff looked like it was varnished right on the the sides ... NOT GOOD ... Link to comment Share on other sites More sharing options...
ChromoTech Posted April 16, 2004 Share Posted April 16, 2004 what are your guys take on running 20w50 oil in a Pathfinder? i got a head gasket leak too Link to comment Share on other sites More sharing options...
somethingcool Posted April 16, 2004 Share Posted April 16, 2004 I run 10w30 Castrol GTX. good oil and it's usually less than $2 a quart... Link to comment Share on other sites More sharing options...
KnightRyder Posted April 16, 2004 Share Posted April 16, 2004 I also run the Castrol GTX 10w 30 and i find it to be good oil too Link to comment Share on other sites More sharing options...
