chapter Posted January 16, 2006 Share Posted January 16, 2006 This morning it's -20 degré Celsius here in Montreal... So when I start my path 2002, there is a strang noise coming from the right side of the engine (driver side) The noise is not steady and it come from something turning... The noise go down when the engine warm up... I have to return to the dealer again but I'm not sure they will find something again... It's hard to find where it comes from but for sure it's on the driver side... Is someone has experience this kind of noise??? Thanks! Also I can heard a litttle valve noise when accelerated... I hope they solve the manifold stud problem because it's the same noise!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
tiagoqx4 Posted January 16, 2006 Share Posted January 16, 2006 Ive experienced this once on my Q.And its my fan belt.it's getting loose haven't changed it 2 yeras since I bought it. Link to comment Share on other sites More sharing options...
94extreme Posted January 16, 2006 Share Posted January 16, 2006 noise? what kind of noise? Link to comment Share on other sites More sharing options...
chapter Posted January 16, 2006 Author Share Posted January 16, 2006 a kind of grinding noise intermittant, not steady.... for sur it comes from something turning but it's not the strap for sure! The noise is strong at cold start. It comes from the driver side of the engine and down. It's like the sound comes from the right down corner of the radiator???? Link to comment Share on other sites More sharing options...
Trialsin26 Posted January 17, 2006 Share Posted January 17, 2006 Water pump maybe? But yours being a 02 I wouldn't think. If it only happens at cold temp and goes away I wouldn't worry too much about it. I live here in TN and in the winter one day it could be 60 degrees F, and the next day 30 degrees F causing my PF to make some funny noise sometimes. I'll give you a hint. When it comes to funny noises and the dealer, if it's not making the noise when you take it in they probably won't find it, and if you go back to many times they will find something but it won't be the cause of the noise. Link to comment Share on other sites More sharing options...
94extreme Posted January 17, 2006 Share Posted January 17, 2006 yeah, check yout PS fluid for sure... otherwise i can't think of anything else. Link to comment Share on other sites More sharing options...
