'90 -> '92 Steering boxes
SteeevO
so this weekend is the big weekend. the conversion begins.
but i noticed teh steering box on the parts pathy has a larger shaft comming out of it? should i use the 92's(parts pathy) box and steering system or should i leave it to be the 90's steering system?
i'm planning on running a steering stablizer and idler arm brace so will the box really matter? does anyone know if one is stronger then the other?
it looks like the 92's is stronger due to the larger shaft size but i'm looking for other opinions.
thnx
steven
the centerlink is diferent too. Personally, I'd compare each part as I go and when I hit a common point (may be at the tie-rods), stop the swap.
It's really difficult to tell from diagrams what the differences are but the part numbers differ so there must be something about it.
