Extended Brake Lines
DZap
Howdy All,
I am putting the Bilstein 3" true lift kit on my 1991 Pathfinder and was wondering about extended brake lines. This is my first time ever doing a lift on anything so I am learning as I am going (apologies if anything I say is dumb).
I was wondering if anyone knew whether I need extended brake lines to support the lift or if stock will suffice, and if so where would I get them. I have looked at quite a few sites at this point and the longest I can find are the Sunsong 17.8" lines on Summit. Any help would be appreciated
I don’t do any crazy off roading. I only went 2” with my lift and am not having any issues.
Something else to do while you are there, make a bracket to drop your e-brake lines down.
With my 2” lift, the e-brake lines were tight. I don’t recall how much I lowered the lines, but I felt it was necessary.
