Front spacer lift
Bigneily1972
You generally can do 31's on stock wheel/suspension, though depending on the year and trim you may have to do a small amount trimming to avoid rubbing at full lock.  a 2" spacer lift should be fine, though it will put some extra CV joint stress. You'll probably be ok if you keep it mostly on the road, though you can beef them up by using Trackmotive CVs
