VLBill
VLBill
Hello all: I am in S. America and just bought a 1993 SE with a Z24s engine, and am having a very difficult and confusing time trying to find out the carburetor model for this vehicle.
The model number of reference that I have been able to locate 16010-21G61, as per Google, but when I type the number on Amazon or Ebay it only references this model for years 84 to 86 on a Datsun or Bluebird, and the pictured model somehow does not look exactly like mine, although Google says it fits my Pathfinder.
There are two or three manufacturers on Amazon that offer this type of carburetor. Additionally, my carb has a manual choke, and these being offered have an automatic choke, for which I do not know if my vehicle will take this installation normally. If anyone has experienced or can provide any ideas I would be very thankful.
HI Bill, I have fitted one of these aftermarket carburettors and had no issue.
If you don't rely on using your choke you could simply cut the cables off the carb, or you may be able to adapt the manual choke mechanism from your existing carb.
Alternatively, you may be able to recondition your existing hitachi carb if the throttle shafts are not severely worn.
The Australian WD21s I have owned (all Z24 Carb) have all came factory with an Auto (electric) choke.
I currently run a DGV38 weber and don't use choke at all and have had Zero starting issues in Freezing to +45 degrees Celsius).
