auto tranny / body lift
Guest Mr. Bungle
Guest Mr. Bungle
I am going buy a body lift kit and noticed at http://www.4x4parts.com/ they have the transmission & transfer case extension, I am sure that this is what is need but I would just like to make sure that I do not have any shifting problems and would like the shifter to look normal.
Does this extension make the tranny shifter look normal or what?
when you complete a body lift does the shift pull down to the floor ?
and is that what the extension is for to make it look and shift normal? :shrug:
If you have an auto transmission, the shifter needs no modifications. The transfer case shifter will sink down into the floor, though. You'll either need to bend the t-case shifter or weld on an extension to make it shift properly after the body lift. You won't be able to put it into 4LO unless it's been modified.
