97 Pathy Coil Springs
merlinx
Hi guys I just realized that my car is lower on the drivers side rear then on the pass side rear. I measures it and I thing the right side was 35" and the Left was 34" Anyone know the stock ride height? Also, I removed the rear coins and the left is just a little lower. Anyone kow where I can get a replacement coil? Should I replace both you think? And if so where can I get a good deal? Not really looking to lift the truck either. thanks
Jason
If you replace the coils, go ahead and replace both. As for the ride height. The PF, at least the 96 and up tend to sag a little on the driver's side b/c of the gas tank. When the gas tank is full you can see about an inch to an inch and a half of difference. Try measuring it with a full tank and then an empty tank. Just an idea???
