Pathfinger Posted May 12, 2023 Share Posted May 12, 2023 (edited) Hey fellas, doing my tranny fluid and just want to ask before i act: Do those 4 bolts sureounding the shifter need to come off to be able to fill, or do I just pour it in that small hole on the side of the shifter? https://i.4cdn.org/o/1683840568892282.jpg Edited May 12, 2023 by Pathfinger Link to comment Share on other sites More sharing options...
Frenchy Posted May 12, 2023 Share Posted May 12, 2023 I have found that either removing the shifter or shifter housing is more than adequate. Also make sure you have GL4 Transmission fluid or the transmission will have problems. Link to comment Share on other sites More sharing options...
Pathfinger Posted May 12, 2023 Author Share Posted May 12, 2023 (edited) dont worry, I bought the good sheeit... MT-90, baby! Edited May 12, 2023 by Pathfinger 1 Link to comment Share on other sites More sharing options...
Frenchy Posted May 12, 2023 Share Posted May 12, 2023 You mean overpriced stuff? You can get Valvoline MTF for about $10 a quart at your local auto parts store. Should I mention it meets the specifications?! Link to comment Share on other sites More sharing options...
Pathfinger Posted May 12, 2023 Author Share Posted May 12, 2023 Hmmmm *ponder ponder*... Link to comment Share on other sites More sharing options...
Frenchy Posted May 12, 2023 Share Posted May 12, 2023 It's ok to question it. If you go strait to Valvoline's website and you can get the answer. That is how I found out. Link to comment Share on other sites More sharing options...
Frenchy Posted May 13, 2023 Share Posted May 13, 2023 Here is the answer strait from the Valvoline website. Make it much easier and more cost effective for us with the Nissan Manuals!! https://www.valvolineglobal.com/en/synchromesh-mtf/ Link to comment Share on other sites More sharing options...
Pathfinger Posted May 13, 2023 Author Share Posted May 13, 2023 nice, that's good to know. Link to comment Share on other sites More sharing options...
Jimmie Posted May 16, 2023 Share Posted May 16, 2023 (edited) Can you use MT-90 on a Pos trac rearend? Do you add any additive to it after the change ? Edited May 16, 2023 by Jimmie Link to comment Share on other sites More sharing options...
Frenchy Posted May 16, 2023 Share Posted May 16, 2023 Why use a manual transmission fluid to a diff.that requires a diff fluid? I used Castrol 80w-90 with Limited slip additive built in and it does well Link to comment Share on other sites More sharing options...
Pathfinger Posted May 21, 2023 Author Share Posted May 21, 2023 Got it done. Taking off the shifter plate was much faster than messing around with snapring pliers. Now it's time to get my interior back in... Link to comment Share on other sites More sharing options...
Frenchy Posted May 21, 2023 Share Posted May 21, 2023 I'm surprised you removed that much. I'm able to do it without removing the seats or the center console. 1 Link to comment Share on other sites More sharing options...
