ERRATIC Tachometer Fix 96-97 R50'S
Mrelcocko
If your R50 is suffering from the tachometer doing a crazy dance or not working at all I have the fix. Only pertains to 96 and 97 model Pathfinders QX4 and Terrano's as these are the only ones that use this style of tachometer. Remove the cluster clear face along with black shroud as one piece. On the backside of cluster there's a printed circuit. Remove the 4 screws that hold the tach in place. Once you have the tachometer removed on the backside of the tachometer where the four screws, screw into you will see 2 soldering points on each corner. Resolder each one of those points along with the four in the very middle that form into a diamond shape. It may take several attempts to resolder, but use a steady hand and take your time you shouldn't have any problems. There's a write up about this fix I found in Japanese. In that write up it said nothing about resoldering the diamond shape points in the middle. In my situation after several attempts of resoldering the 2 points on each corner and not fixing the tach, one time of resoldering the diamond middle it fixed my issue. I've included a pic of the newer style R50 tach just to show the difference. Didn't have a pic of the clusters printed circuit. Good luck NPORA members.1b8ecadf7400b862e03568a9343737b2.jpg9aa92dbc0d48e52c061687ab4a3afef7.jpg4f783f62b76bf852c32a375bef312b82.jpg505dcb82acd03c5a132b88e5ee60d05c.jpgf2dc02d733e55b729fb2d0bb721d8194.jpg
Sent from my SM-S367VL using Tapatalk
