TroyButler Posted June 29, 2019 Share Posted June 29, 2019 (edited) Hello, Last night/today i decided to install my SF rear lift spacers (will be doing front soon) and today had to replace my front caliper due to the old one being seized. I replaced both sets of pads and bled the brakes. Fluid is all topped up and the pedal builds up pressure and does stop the car fine. Slight rubbing sound from passenger side brake but thats all. Any ideas as to why my brake light may be on? did i do something wrong in the front or bump something in the rear i should check? Thank you Edited June 30, 2019 by TroyButler Link to comment Share on other sites More sharing options...
Guest Posted June 30, 2019 Share Posted June 30, 2019 (edited) did you get air in the abs module? I believe this is similar to what happened with @hawairish Edited June 30, 2019 by Astrorami Link to comment Share on other sites More sharing options...
TroyButler Posted June 30, 2019 Author Share Posted June 30, 2019 Just now, Astrorami said: did you get air in the abs module? not sure? only bled the 2 calipers nothing else? Link to comment Share on other sites More sharing options...
Guest Posted June 30, 2019 Share Posted June 30, 2019 Just now, TroyButler said: not sure? only bled the 2 calipers nothing else? did the fluid in the reservoir go nearly empty when pumping brakes? Link to comment Share on other sites More sharing options...
TroyButler Posted June 30, 2019 Author Share Posted June 30, 2019 (edited) 4 minutes ago, Astrorami said: did the fluid in the reservoir go nearly empty when pumping brakes? Yeah, once, my partner said the pedal went soft a couple times and i added fluid to fix it Edit: wouldn't that throw and ABS light then not (E)brake? Edited June 30, 2019 by TroyButler Link to comment Share on other sites More sharing options...
Guest Posted June 30, 2019 Share Posted June 30, 2019 (edited) Could possibly have air in the module. Easy way to fix is with an obd computer that will actuate abs system. Edit: you may be correct about abs light. I read it wrong initially. The only time I've had a BRAKE light was when my pads were near gone and fluid was low. Edited June 30, 2019 by Astrorami Link to comment Share on other sites More sharing options...
TroyButler Posted June 30, 2019 Author Share Posted June 30, 2019 3 minutes ago, Astrorami said: Could possibly have air in the module. Easy way to fix is with an obd computer that will actuate abs system. Ill have to look into one.. do you know what the LSV air bleeder is thats referenced in the Service manual? Link to comment Share on other sites More sharing options...
Guest Posted June 30, 2019 Share Posted June 30, 2019 1 minute ago, TroyButler said: Ill have to look into one.. do you know what the LSV air bleeder is thats referenced in the Service manual? I have no experience with the load sensing valve (LSV). You may have to bleed that if you have it. Link to comment Share on other sites More sharing options...
TroyButler Posted June 30, 2019 Author Share Posted June 30, 2019 13 minutes ago, Astrorami said: I have no experience with the load sensing valve (LSV). You may have to bleed that if you have it. BR-7 Page 8 https://nicoclub.com/FSM/QX4/1997_QX4/br.pdf Is it possible to be from just having the rear lift in or am i misinterpreting that wrong Link to comment Share on other sites More sharing options...
Guest Posted June 30, 2019 Share Posted June 30, 2019 1 minute ago, TroyButler said: BR-7 Page 8 https://nicoclub.com/FSM/QX4/1997_QX4/br.pdf Is it possible to be from just having the rear lift in or am i misinterpreting that wrong I really do not know. Rather than give false info, maybe someone else can chime in... Link to comment Share on other sites More sharing options...
TroyButler Posted June 30, 2019 Author Share Posted June 30, 2019 Sometimes i forget the age of these vehicles. this may not apply to everyone if they have this problem, but for me, when the fluid went low i assume it sucked the level sensor float with it and it got stuck to the bottom, so i just unplugged the sensor and gave a "technical tap" with a screw driver to the reservoir, and after just turning the vehicle back on the light is currently off. Will update if it comes back on. Link to comment Share on other sites More sharing options...
