Guest 96pathfinder4x4 Posted April 10, 2005 Share Posted April 10, 2005 Can anyone help me in locating the pump for the rear window washer on a SE model? I removed the right rear lower panel and found what looked like an amp along with some connections. Any help is appreciated. Also, if you know whether I can replace the pump with a generic one. Thanks in advance. Ray Link to comment Share on other sites More sharing options...
nick1716 Posted April 10, 2005 Share Posted April 10, 2005 i replaced mine not to long ago... its right on the box where you pour the washer fluid into in the front passenger wheel well behind the plastic liner.. it about 30 bucks for the pump Link to comment Share on other sites More sharing options...
Guest 96pathfinder4x4 Posted April 10, 2005 Share Posted April 10, 2005 i replaced mine not to long ago... its right on the box where you pour the washer fluid into in the front passenger wheel well behind the plastic liner.. it about 30 bucks for the pump Thanks for the reply. Is it separate from the one for the front windshield? Because that one works fine. Thanks Link to comment Share on other sites More sharing options...
nick1716 Posted April 11, 2005 Share Posted April 11, 2005 yea theres 2 different pumps comin out out of the same washer box. they look exaclty the same so make sure you yank outt he right one... and the washer fluid is going to go everywhere when you do so have a clean bucket or somethin ready so you can pour it back in Link to comment Share on other sites More sharing options...
