Heads up on steering column covers
ahardb0dy
Just a heads up, I just bought a used column cover from a member on another forum and went to install it and came across a problem, not his fault, I never even knew there was a difference in the top covers, this probably wouldn't be an issue on the Pathfinder a most probably came with tilt steering, just wanted to share what I found.
pic below is the stock cover from my 93, non tilt that I modified to fit the tilt column, you can see the opening for the ignition cylinder is towards the rear.
New/used tilt column cover from a 90 Pathfinder, you can see the opening for the ignition cylinder is towards the front:
I also noticed the bottom cover from the 90 Pathfinder is not as deep as the one from my 93, but the bottom cover would have worked, I just had to move all the wires to the right side
