Aftermarket wheels?
Andrew6091
Im sure this topic has been discussed time and time again, but Ive recently bought 20x9 American racing AR910s for my 2001 pathfinder (I believe they have a 5.5 or 5 inch BS). I ordered some 265/50r20 nitto terra grappler g2 tires for them. I wont be home for another month to put them on. Im just curious to see if anyone else is running 20s on theirs and what kind of fitment issues they have. I took the mud flaps off a long time ago, and I have a 2.5 in lift, so I think ill Be alright with the fitment. Im just worried about having to cut or trim.
Those should fit perfectly fine. Tire size is withing the specs for stock-backspacing wheels, and the backspacing you have is the same as stock. It should fit just like the original wheels and tires do! (But look better of course! :happy: )
I am running 20x9 MB Chaos 6's wrapped in 275/55's. Believe they have the same backspacing as what yours will have.
2.5"lift. Required some trimming of the front bumper and a small portion of the inner fender well where the mud flaps are currently located. Don't think you would need to do thi s with the 265/50's though.
I have a build thread on here with many more pics and close ups of needed cuts. Search 03troutfinder build thread to see if you can find it.
It does still rub at times when turning really sharp but nothing unsafe. Probably just need to trim a small amount more since it settled in.325067ea2a9b2a570ffbe6f9c98ff5ca.jpgc1565636f3320c2b2f71bfba6338ea49.jpg
Sent from my SAMSUNG-SM-G930A using Tapatalk
