agent22 Posted January 21, 2018 Share Posted January 21, 2018 im doing the swap now on my 1988 pathfinder, with an 2000 xterra motor, what motor mounts do you use, because they aren't the same mounts? Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted January 22, 2018 Share Posted January 22, 2018 im doing the swap now on my 1988 pathfinder, with an 2000 xterra motor, what motor mounts do you use, because they aren't the same mounts?Reuse your mounts or buy new ones of yours. Sent from my SAMSUNG-SM-N920A using Tapatalk Link to comment Share on other sites More sharing options...
agent22 Posted January 23, 2018 Author Share Posted January 23, 2018 i think i get what needs done I just need someone that has done the swap to confirm. the brackets off my old wd21 engine(VG30i) can be used on the new engine(VG33E) putting in. they should just bolt to the side of the engine, right? Link to comment Share on other sites More sharing options...
vagabond Posted January 28, 2018 Share Posted January 28, 2018 (edited) yes I'm on my 2nd swap updating to 95 wiring and dash power windows and powerand heated mirrors Edited January 28, 2018 by vagabond Link to comment Share on other sites More sharing options...
agent22 Posted January 28, 2018 Author Share Posted January 28, 2018 thank you Link to comment Share on other sites More sharing options...
