thewiredgeek Posted March 29, 2005 Share Posted March 29, 2005 Can anyone tell me how hard it is to take the factory nerf bars off? I've looked at the mounting bolts, but I can't tell if they have nuts behind them, or if they are simply screwed in. I have a 45 minute window to get it done and I am just wondering if that is going to be enough time. Thanks!!! Link to comment Share on other sites More sharing options...
Pezzy Posted March 29, 2005 Share Posted March 29, 2005 not sure... mine came 'sans' step rails if theyre anything like the Xterra's - it's a matter of removing a few bolts... and theyre pretty light... It's suggested that once you remove them to place the bolts back on the truck, so the holes dont get full of crud & whatnot, which makes it easier for when you put them (or others) back on... Link to comment Share on other sites More sharing options...
rosspbig Posted March 29, 2005 Share Posted March 29, 2005 When i took mine off it was quite the process. As i remember it they had both bolts and nuts on em. they were a big pain to get off cause the bolts and nuts were rusted and stripped! Link to comment Share on other sites More sharing options...
big_johnson Posted March 29, 2005 Share Posted March 29, 2005 When I took mine temporarily off, it was a simple operation. Just make sure you have the right tools, some of the bolts are hard to get at without ratchet extensions. Putting them on is a bit harder, especially by yourself Link to comment Share on other sites More sharing options...
Gorilla Man Posted March 29, 2005 Share Posted March 29, 2005 Mine was simple. 6 head-head bolts on each nerf bar (3 mounting brackets, two bolts on each) and all the same size. So just take a ratchet and socket and have at it. I just remember there being one or two that were a hard angle to get at. Link to comment Share on other sites More sharing options...
thewiredgeek Posted March 29, 2005 Author Share Posted March 29, 2005 Thanks for the feedback guys. So, as long as I don't have a lot of rust (Not holding my breath), this should be easy. Link to comment Share on other sites More sharing options...
thewiredgeek Posted March 31, 2005 Author Share Posted March 31, 2005 Thanks again for the feedback guys. I ran into a little rust on the passenger side, which slowed me down a little. Lucky for me, it took exactly 45 minutes. Link to comment Share on other sites More sharing options...
