2003 engine miss
lakehouse
Swap coils around see if the miss follows or doesn't. If it does you have a bad coil out of the box. Not unheard of. If it doesn't, could be a broken plug (oopsies on your part) or bad wiring somewhere in the harness.
Could be a bad injector as well, or wiring there again.
Hopefully not a mechanical issue.
