front driver signal light housing
Moses
Need help with my '96 pathfinder...front driver signal light housing...is there a trick to get it out ? Haynes manual says to unscrew (this screw with arrow) did that but it does not come out & I don't want to break the lens ...any suggestions would be most helpful :)
Here are 2 pics that I hope they help. It wasn't hard. Just remove the screw on top, use a flat head wrap on a rag and pry/push the light forward. It should pop out from the white hole you see at the bottom.
