towncarblue Posted June 17, 2016 Share Posted June 17, 2016 (edited) in recently took apart my intake manifold in my 2002 nissan pathfinder. unfortunately i do not know where the swirl control valve solenoid valve connects to. does it connect to the intake box or the vacuum switch assembly ? i had a p1130 error code after i removed the intake manifold. i took it apart again to make sure i put it in correctly . the code kept popping up. i went and ordered a brand new tank assy-pressure { 22370-4w01a } and the code keeps popping up. i replaced almost all the vaccum hoses { could not get the one that goes behind the tank assy pressure , i have no idea how to replace that one , its tight and i lose sight of it} can someone let me know where the Swirl control valve/control solenoid valve connects to ?? 22370-4W01A TANK ASSY-PRESShttp://www.nissanpartsdeal.com/parts/nissan-tank-assy-press~22370-4w01a.html vacuum switch http://www.courtesyparts.com/oe-nissan/223602y900 Edited June 17, 2016 by towncarblue Link to comment Share on other sites More sharing options...
towncarblue Posted June 17, 2016 Author Share Posted June 17, 2016 nevermind . found a pic. turns out i had the valve connected to the vacuum switch instead of the intake. Link to comment Share on other sites More sharing options...
