FRONT DRIVE SHAFT REPLACEMENT
Good morning all,
For the past few months, I have noticed a vibration coming from the front end of my truck. I finally had some time to diagnose the problem and found that the front drive shaft u joint is done. From what I am reading the whole drive shaft has to be replaced. My question is, does anyone offer a serviceable drive shaft that I can just replace the u joints in the future?
Thank you,
Scott
Yeah you can replace the u joints. It's pretty easy just take the shaft out then press out the old one and press the new one in. Just be careful not to loose the needle bearings that are in the caps.
