Little Help
Jairo2000
I think what you're referring to is a combination of the ECU and an assembly of things inside the distributor. There is an LED, under the rotor base plate, that shines a light at a metal ring with slots in it, the light triggers a diode which sends an ON-OFF signal to the ECU which determines the timing of the primary winding collapse and spark event to the plug.
Uhh...AND: the ECU is located under the front passenger's seat.
Okay.. yea... ummm.. that's it then.
