Brake controller Wiring.
dml996
I recently purchased an RV that has electric brakes and decided to attempt to install a Brake controller in the Pathy.
I have installed all of the Wiring with the exception of hooking it up to the brake wire under the dash.
Has anyone else done this before and if so which wire do i need to tap?
There is a video online that shows this process on a 2001 Xterra in which the mechanic taps into a brown and siler wire behind the brake pedal so i'm guessing this may be the same on the pathy.
Has anyone else been here before and if so what wire do i need to tap?
Unplug the switch and see which wire is Hot with a multi-meter. Then splice into the wire that is not. Make sure you use a relay with 10 or 12ga wire going to the trailer braking system.
Edited by MY1PATH
