Soninihon Posted November 2, 2015 Share Posted November 2, 2015 Help on installing running board. I pick them off from a LE. When I took it off, the front bracket was wrap around the frame. Thinking my pathy have one, I didn't grab it as I didn't know how I'll take it off since it's wrap around the frame. When I look under my pathy after my purchase, I notice it did not have any bracket to bolt it on. Question is: how to bolt it on or what's the right bracket? Running I pick up Back fits just right No where to mount on front Now I found this on ebay. It looks like it has the right bracket and it's off from Se. Could it be this bracket I'm looking for? If so what is the part number. If not, then how would I go about to remove that wrap bracket? Link to comment Share on other sites More sharing options...
Kurruppt Posted November 2, 2015 Share Posted November 2, 2015 (edited) there should be just 2 bolts per bracket that er its a 2 piece. if you need a pic i can go find my others and take a pic. if i remember loosen the back bolt then remove the front bolt and it should just come off if you turn it. on each bracket Edited November 2, 2015 by Kurruppt 1 Link to comment Share on other sites More sharing options...
Kurruppt Posted November 2, 2015 Share Posted November 2, 2015 Link to comment Share on other sites More sharing options...
Soninihon Posted November 2, 2015 Author Share Posted November 2, 2015 there should be just 2 bolts per bracket that er its a 2 piece. if you need a pic i can go find my others and take a pic. if i remember loosen the back bolt then remove the front bolt and it should just come off if you turn it. on each bracket Thank you. Now I have to wait til next weekend to go back to junk. Hopefully it'll still there. Link to comment Share on other sites More sharing options...
Soninihon Posted November 8, 2015 Author Share Posted November 8, 2015 Well I was able to pick it up at junk. One of the bolt snap so I have to break it off Now. But good thing it was still there Link to comment Share on other sites More sharing options...
